Many choose to throw the gasket away...
and Proseal directly to the cover. The gaskets have proved to be problematic in the past. The sender is supplied with a gasket but that does not mean you have to use them. If you are showing signs of a leak now, take care of it. It will probably only get worse over time.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
