long enough to cut threads and tapper the end...
i think that i bough 5" or so... after cutting the threads i chucked the bolt in a drill press and tapered the the bolt end with a vixen file, then smoothed with files and emery cloth.
just make sure that the bolts are straight... lower grade hardware has a lot of variation.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
