Old 12-12-2010, 07:45 PM
Maxrate Maxrate is offline
Default flap paint protection / anti scuff tape
After doing several searches I have come up empty on a good alternative to the Vans supplied UHMW tape. Several threads mention a tape by 3M called RockBlocker, but 3M website doesn't recognize that name. What might be a good alternative to the standard tape sold by vans. I want to get something that won't discolor.
Thank's all,
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
Old 12-12-2010, 07:53 PM
docskj's Avatar
docskj docskj is offline
Put the tape on the bottom side of the top skin where the flap will rub. That way, when the tape discolors, no one will see it.
Old 12-12-2010, 08:39 PM
dpansier's Avatar
dpansier dpansier is offline
Vince, a Rocket builder, has the 3M protection film here:
http://www.flyboyaccessories.com/sto...oosfb727v869q4
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 12-12-2010, 09:58 PM
erich weaver's Avatar
http://www.vansairforce.com/communit...ighlight=Erich
Here is a thread identifying another source that I think provides a few more options on the tape. I've had it on my flaps for about 3 years now (outside unfortunately) and it still looks great.
Erich
Old 12-12-2010, 10:22 PM
scsmith scsmith is offline
Default I used the PM Research tape
The same thing that Erich mentioned. See his thread link.
You can buy just the length you need, it is easy to apply, and it looks great. After a full year, it looks like brand new except for the areas where there is some scuffing from the skin, and it is doing its job.
The instructions were complete, it was easy to do well. Highly recommended.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 12-13-2010, 03:25 AM
Default Stainless Steel and the Van's Tape
I put stainless steel tape on the flap and the plastic tape from Vans on the mating underside of the wing skin. That has worked well for me (7 years).
Bob Axsom
Old 12-13-2010, 05:14 AM
Thanks for the info and links gents.
Mark Malone, RV7
N442MM reserved
Old 12-13-2010, 07:32 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Putting the tape alone on the underside of the wing skin instead of the flap itself still lets the paint on the flap get scratched up pretty quickly because of tiny dirt particles getting trapped in there in between the flap and the tape. We found that one out the hard way.
Neal Howard
Airplaneless once again...
Old 12-13-2010, 07:40 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I concur with that. I recently changed out the five-year-old tape on my flaps because it had gotten brittle and yellowed. Took me a couple of hours - not bad for aircraft maintenance. I almost went with putting the new stuff under the wing skin, but then thought about the fact that all the scratches in the old tape were caused by grit - and if the tape under the skin got dirt in it, the scratches would be in the paint.
Others have had good experiences with the flap under the skin - I just throw this out there for your consideration...
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-13-2010, 03:38 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
For the same reasons, I've used this tape on the upper fuselage where the sliding canopy closes & rubs against. I've seen numerous RV's where the paint is scratched or rubbed off under the canopy.
L.Adamson --- RV6A
