Old 12-12-2010, 06:11 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default Smoke system benefits/uses
Rather than have my review of the Smoking Airlines system become a thread on uses, it makes more sense to discuss uses/benefits here.
Initially I was going to use it when ATC called out traffic (usually never seen) plus during flights when smoke would be beneficial for ground based observers.
Then two other uses were mentioned:
1) During departure/arrival to an airport when other aircraft have not found you yet.
2) To help form up when aircraft are miles apart (such as arriving from different starting points).
Today, just days after my smoke system became operational, I had my first valid use. I had taken off after two other RVs with the intent to get some performance data. When I heard the other RVs discussing the worse than usual turbulence, I changed plans and decided to try to find them.
I headed north and waited until they were headed south. Several seconds of smoke and they found me right away. I did not see them (about 1500' lower) until they told me I was overhead, turned left and saw them.
No discussing distance and heading to our airport. They had me far quicker than the way we normally try to join up.
Then during the overhead approach I looked down and saw a nice shadow from the smoke.
The only negative is that another RV pilot was driving and saw me and thought that the plane with the smoke was a Yak.
Old 12-12-2010, 07:49 PM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Another good use for smoke...
Burning money. At over $300 per hour!
(0.8 gal per minute times 60 minutes times $8 per gallon = $384 per hour!)
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 12-12-2010, 08:14 PM
Ron Lee's Avatar
Avoiding mid-airs: priceless.
What are you using that is only $8 USD a gallon. I am pleased that once I get through the $17/gallon stuff I have it drops to $10/gallon.
Old 12-12-2010, 08:18 PM
ronschreck's Avatar
I don't buy it at all any more. Too expensive for me. I let the air show organizers buy it for me.
Ron Schreck
IAC National Judge
VAF 2021 Donor
Old 12-12-2010, 08:36 PM
tcone1's Avatar
tcone1 tcone1 is offline
Default TCAS or PCAS
I smoke during all of the previously mentioned phases of flight AND
any time my Zaon PCAS tells me there's a transponder in the vicinity.
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
Old 12-12-2010, 08:53 PM
Mel's Avatar
Mel Mel is offline
Default If you flew much around DFW......
You would have it on about 95% of the time.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-12-2010, 10:05 PM
db8's Avatar
db8 db8 is offline
Default Smoke oil
So why not use straight diesel like Tony Spicer has in his smoke system? Seems like it should work pretty well and cost a lot less. That's my plan unless I am missing something here? Thanks. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 12-13-2010, 05:52 AM
ronschreck's Avatar
Default Why not?
BOOM!
Ron Schreck
IAC National Judge
VAF 2021 Donor
Old 12-13-2010, 05:56 AM
ronschreck's Avatar
Default To be more specific....
! WARNING ----- WARNING ----- WARNING !
DO NOT USE FLAMMABLE SUBSTANCES SUCH AS GASOLINE OF ANY TYPE, KEROSENE, DIESEL, JET-A, ALCOHOL OR ANY OTHER FLUID NOT LISTED ON THIS PAGE.
USE OF HIGHLY FLAMMABLE FLUID COULD CAUSE AN EXPLOSION
OR FIRE RESULTING IN SERIOUS INJURY OR DEATH.
Ron Schreck
IAC National Judge
VAF 2021 Donor
Old 12-13-2010, 07:55 AM
db8's Avatar
db8 db8 is offline
Default My Bad
I'm with ya....my bad. I understand.
Dave Buntin
