Old 12-11-2010, 11:02 PM
tx_jayhawk tx_jayhawk is offline
Default Alternate Fuel Sender Ground
All,
The tanks are sealed, and I am needing to finsihing the fuel float sender wiring. Since the tanks are sealed and I don't want to disrupt that, I would rather not use one of the sender mounting screws as a ground. I'm wondering if people have found acceptable results with grounding it to another screw in the area (tank attach bracket, etc.).
Scott
Old 12-12-2010, 08:01 AM
flion's Avatar
flion flion is offline
Depends on your gauge. I planned to use common ground but found my EFIS was sensitive and had to run the ground direct. That meant isolating the sender even from the tank. I did a brief write up with pictures here. Note: I went with the cork gaskets for the sender plates and the rubber gaskets for the sender itself, rather than prosealing everything in permanently.
EAA Technical Counselor #5357
Old 12-12-2010, 10:24 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I ran a separate ground wire from one of the screws of the sender directly to the ground bus. Rock solid fuel readings, never a problem.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
