Originally Posted by jcoloccia
Here's the response I got from Vans:
We see this occasionally on some of the spars when they come back
from Phlogiston (spar assemblers).
Structurally not a problem. Haven't heard reports from the field
that it worsens. Wouldn't hurt to clean it up and prime the area,
however.
So there ya' go...prime it and move on
John, I don't want to worry you unnecessarily but I don't think Vans knows exactly what the phenomenon is. And there is some small possibility that it could be an indication of a batch metallurgical defect rather than minor localised surface pitting (not likely...but possible) in which case "cleaning and priming" might only be window dressing. So if I was you I would go directly to Phlogiston Spars and ask for a professional metallurgical opinion on the specific cause of this defect. This is, after all, the most structurally important member in the plane. You want an expert opinion...not a guess.
You might then like to report back to this group.
Not long back I found that the AFP electric fuel boost pump supplied by Vans was not assembled in accordance with the drawings and one of the fuel lines conflicted with the fuel filter. When I contacted Vans about this they told me to "back off" a pipe thread connector and manually realign the tube.
However I felt that this was not good aviation practice so I went to AFP (Air Flow Performance) the manufacturer of the pump. I received a response from the head honcho and number one design guru himself, Don Rivera. He said that not only was it bad practice to back off the pipe thread but that it would invalidate the warranty.
Many builders assume that Vans is the fount of all knowledge in matters pertaining to aviation...but that is not necessarily the case.
