12-10-2010, 09:32 AM
Flap control - Auto up-down like car windows?
I'm sure people will tell me why this is a silly or impractical idea, but i'm curious.
My car window has a single switch to control it, that seems (to me) to have five positions. If I pull or push it lightly, I get control over where I want the window, and I can raise or lower it a little bit when I want to. If I pull or push to the limit, it goes into "auto up" or "auto down" mode, and it drives the window to it's limit before stopping.
Is something like that possible on the flap mechanism? I think you'd need a 5 position switch... on-(on)-off-(on)-on. Are those even made? I suspect in the car that it's done with a microcontroller, and a simple (on)-off-(on) switch, as even though I pull the switch all the way to the stop, when I release it the switch comes back to center but the window keeps moving.
Anyone have ideas how to implement that?
Rob Prior
12-10-2010, 09:40 AM
I am No electrician however, is there a reason a switch out of your vehicle wouldent work? Take the guts out of it, implement a new handle/knob and wire it to the motor? Im sure there is a reason bc that just seems to easy. I love the idea tho, I want to be able to hit the switch and forget about it.
-david
RV-7 N87DX Built, Flown, and Sold!
12-10-2010, 09:46 AM
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Senior Curmudgeon
Dont re-invent the wheel here, ShowPlanes already makes a unit that does almost the same thing, plus it has stops for half flaps, and in the case of my 10, take off position.
Check them out.
http://www.showplanes.com/index_1024.htm
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-10-2010, 10:05 AM
Rob, I likethe way you think.
The VP flap controller does almost the same thing. You can bump the flap switch to go to the next postion, and stop it at any time by pressing the opposite switch direction.
I have that same type of switch in my car too. Might be a bit too sensitive for turbulence though.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
12-10-2010, 12:32 PM
Do you really need (want) both a hold and a "bump" option in both directions? Do you want to reduce a flap setting by a bit, or is up flap an "all the way" function?
If it's a quick, "all the way" retract option you want, then a ON-OFF-(ON) switch would work with the momentary (ON) being in the down direction.
The addition of an up-limit microswitch will give you this function with only a simple inexpensive change to the flap circuitry - circuits are here on VAF.
Some certified planes are wired this way, enabling a quick tap of the flap switch to fully retract the flaps for a go around.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
12-12-2010, 12:41 PM
"I think you'd need a 5 position switch... on-(on)-off-(on)-on."
I looked for a part like that recently -- I even asked 'lectric Bob about it -- but no dice. DP5T switches aren't too common, unfortunately.
12-12-2010, 12:54 PM
I would be afraid of a full auto-up flap switch.
I was in a '65 Cessna spam can going into an unfamilliar airport at night. I decided I was too high and needed to do a go-around. I established a positive climb and reached over to bump up the full flaps to half. This was the old sytle toggle switch. The flaps fully retracted and caught me off guard. ( I guess the switch stuck). Not knowing what was ahead in the black abyss really concerned me as I began to sink.
I like my simple toggle in the -7A. No auto up for me.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
12-12-2010, 01:19 PM
But don't most of the low wing spam cans use no flap for a go-around? ....your problem would then not be a problem...
I actually find it easier on the Grumman - tap the switch into the up position and forget about it, no holding it in position for 4 or 5 seconds.
Gil Alexander
12-12-2010, 07:45 PM
I have FPS-Plus installed in mine and love it. You can set as many stops as you want but three is more then enough for RV flaps. It also can control your trim tab if you have an electric trim. One push that is held more than a second takes it all the way down or all the way up and I have a second (manual) switch as a redundancy and in case of failure. So far little over 300 hours on the plane and rock solid. I love it.
http://www.aircraftextras.com/FPS-Plus.htm
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
