Old 12-09-2010, 08:49 PM
Cfrisella's Avatar
Cfrisella Cfrisella is offline
Default Working in the tail
Hey all. What's the best way to work inside the tail. It's time to run the rudder cables and I'm worried about crawling that far in. Obviously need some support, but would like to hear some success stories. Thanks
Old 12-09-2010, 09:12 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I used plywood work platforms that were given me by a previous RV-8 builder when I did my -8. With the -3, we tried something different - we filled the bottom of the fuselage between the bulkheads with moving blankets, right up to the level of the bulkhead openings. Add another layer or two on top of those, through the bulkheads,and you will distribute your loads very evenly over the belly skin. It's worked well so far, and the -3 is VERY tiny inside, so I was afraid of damage just due to being so closed in, and elbowing the skin. No damage to date, and much more comfy than hard plywood...
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-10-2010, 04:50 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Worked for me...
To gain efficient access in the -8, I referred to DWG 42:
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 12-10-2010, 09:39 AM
trib trib is offline
Default Don't forget support beneath the fuselage!
I used the plywood temporary floors also, with some foam padding and blankets thrown on for comfort. Make sure you support the tail from the floor, unless you want to do a wheelie in your shop when you start crawling aft . I used a black and decker workmate below the tail with a 4" blue styrene foam block between the workmate and the thicker aftmost skin. It was wedged in tight, initially and compressed just a bit when I crawled back, and adequately spread out the load while the hull remained stable.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 12-10-2010, 09:48 AM
aerolite aerolite is offline
Default plywood as well...
used 1/2 inch and set on bulkheads. Added another piece to make step at aft baggage bulkhead so aft fuse plywood rested on that. Worked well and no damage to anything. Alot of grunting and groaning though
Steve Busby- Bearhawk Aircraft Canada
RV's:
-7 Completed
-12 Started
-9A repaired
-8 finished
ect.
Non RV's:
a bunch of stuff
www.aeroliteflight.ca
Old 12-10-2010, 09:50 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Plywood also
Another ditto for the plywood, in my 10.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-10-2010, 04:56 PM
Phil's Avatar
Phil Phil is offline
Lots of phone books stacked above the bulkheads and then a blanket thrown over the top worked well for me.
Old 12-10-2010, 05:58 PM
John Tierney John Tierney is offline
Default Cardboard Template
To find the right shape for my plywood temporary floor I first cut out the shape on heavy corrugated cardboard, and trimed and adjusted until I was satisfied. It does stink when you drop things and they roll under the plywood as you are laying on it.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 12-10-2010, 07:57 PM
Cfrisella's Avatar
Thanks all. Lots of good ideas. Never thought I'd need all those old phone books. Dang
