12-08-2010, 07:26 PM
How much voltage is too much?
I just installed a new (Mark Landoll) alternator. It is putting out 14.7 or 14.8 the info that Odyssey (PC 680) says keep it under 15v but am I too close doing any damage?:
Steven Goldin KTAN ( south of Boston)
RV 12
RV6-A sold
VAF 2464
401-338-9747
sgoldin1@gmail.com
12-08-2010, 08:03 PM
220 or even 120v would be too much  but I think you are OK with 14.7 only keep an eye on it. Also how are you checking your voltage and does it remain the same voltage with various RPM? Some regulatros are adjustable.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
12-08-2010, 08:10 PM
I'd be ok with that, are you measuring with an accurate digital voltmeter?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-08-2010, 08:49 PM
And at the battery.......
12-08-2010, 08:51 PM
steve, i think you can tweek that external regulator with the adjusting screw.
hows the wx in the north?
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
12-08-2010, 11:46 PM
I've found that if you go over 14.2V at the battery that you will use more water if it's that kind of battery. The regulator I designed and built holds the voltage to 14.0V. If you have a temperature probe connected to the battery case feeding a regulator that compensates for battery temperature then it will provide the proper voltage but that kind is seldom seen.
12-09-2010, 09:07 AM
thanks info
The regulator is internal so no adjust, the monitor is EIS from Grand Rapids, the voltage does not change with RPM very steady. So I guess I will leave for now.
Steve
RV 12
RV6-A sold
VAF 2464
401-338-9747
sgoldin1@gmail.com
12-09-2010, 05:09 PM
Over voltage protection
Back in the mid-90's a friend of mine had a Landoll alternator on his RV6. The built in regulator failed and the voltage went high, uncontrolled. No telling how high the voltage got, but it fried quite a lot of things in his panel instantly.
I'd suggest putting in some kind of over voltage protection, unless the newer Landoll alternators/regulators have that incorporated these days. Cheap insurance...
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
12-10-2010, 10:22 AM
OVP
ordered from perihelion design OVP anyone ever use one?
RV 12
RV6-A sold
VAF 2464
401-338-9747
sgoldin1@gmail.com
12-10-2010, 03:40 PM
pc 680 paper work
if i remember correctly in the pc 680 paper work they give voltages for charge. and if I remember correctly 14.8 is perfect, anything less is less than 100% charge. My odyssey battery charger charges at 14.8.
Noel
Noel Simmons (repeat builder) just ordered my 40th it's an 8!
406-538-6574
A&P CFI EAA Tech/EAA flight adviser
