Old 12-07-2010, 08:04 PM
rv9aviator rv9aviator is offline
Default Starter switch options.
I would like to use toggle switches for the mags ( one impulse and one without on 0-320 E3D). Also I want to use a momentary toggle switch or push button for the starter. How do I make sure I don't have both mags hot when starting? I'm afraid I will leave both on and screw up the starter and flywheel at some point.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 12-07-2010, 11:59 PM
shamer's Avatar
shamer shamer is offline
Default Starter switches
Look in the Aerolectric Connection if you have one. It has exactly what you're looking for. If you don't have the book, I could fax you what you need.
Steve Hamer
RV-6
Eagle, ID
Old 12-08-2010, 05:51 AM
Thanks. I found what I was looking for.
Jim Wright
