I've started working on my spinner and would like to install my Sensenich fixed prop for the first time. Piece of cake right?
Just to confirm,
My IO-360 crank has a black "0" next to one of the more recessed prop bolt holes on the flange.
The starter ring has a stamped "0" next to one of the holes.
The Sensenich 2 1/4" spacer has a "1" stamped on the side next to one of the holes.
The prop really doesn't have anything but can only go on 2 ways. One or the other blade lines up with the said marks. There is a "T" stamped near the transition from the center to one blade, but it doesn't really line up with the marks.
Line up everything and bolt it on??
Also the prop spacer studs that go into the prop are very snug. When I sandwich the spinner backplate between them I'm thinking it'll be real tough to get them back apart.
What's the best way to install the spacer to the prop since it's so tight? Slowly tighten each prop bolt a little at a time? What's the best way to seperate the spacer and prop again if you want to get the spinner backplate out?
Thanks!
