12-05-2010, 08:25 PM
Master and starter relays
The plans call for these two to be mounted right underneath the battery, screwed into platenuts on the two stiffeners and a backing plate. Problem is...I don't think they're going to fit there. There's *just barely* not enough room because the doubler plate for the fuel line (positioned exactly according to plans). I really don't want to take that off...it's riveted in, hard to reach now to drill out, painted, and sealed with RectorSeal. In short, a mess to take off and trim.
I'm thinking of a doubler plate (layered, actually, 4" x 6" .063, 2" x 4" .032) on the firewall, just below and right of the battery (looking forward).
Anyone else have this problem? Anyone have any other ideas for mounting these dudes? Trying to keep wires shorts, obviously, but also accessible.
Thanks...
Steve
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
12-06-2010, 04:40 AM
I can't view your pictures from work but typically, you want the master solenoid as close to the battery as practical and the starter solenoid where it is convenient. It can go anywhere really. Put them where you can get at them and continue to move forward.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
12-06-2010, 06:29 AM
Steve,
What type of plane is it?
Tony Phillips
N524AP, RV 9 (tail wheel)
12-06-2010, 10:50 AM
Contactor - Needed?
Steve, I didn't have any issues mounting these, and all of my stuff was mounted per plans. I don't recall how close these items were to the fuel line feedthru.
One other thing to consider is whether you will need a starter contactor on the firewall. The Skyweight starters have a solenoid that is jumpered, but the way it was intended to work is that when the pinion gear engages, the contacts close and the motor starts. If you look at the wiring diagram for the starter, they advise removing the jumper in experimental installations and wiring the starter switch directly to the starter, eliminating the contactor on the f'wall. In certified installations, the STC does not allow removing the start contactor from the A/C. One disadvantage of wiring this way is that the starter cable is always hot. One advantage is that the installation is simpler and lower weight with fewer components.
I didn't realize this when I built mine, just built it per plans. I could go back and change it but probably won't since it is all wired.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
12-07-2010, 01:26 AM
No Instructions for such items on my RV-6A
No Instructions for such items on my RV-6A and I don't know what type of airplane you are building but I just looked for a good mounting surface near the battery. The battery is on the floor center up against the firewall. I installed the two units on opposite sides of the left of three structural members running from the firewall to the instrument panel under the fwd upper fuselage skin. No problems in 600 hrs of operation.
Bob Axsom
