Old 12-04-2010, 12:13 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Default Center section gap
Went to bolt my wings on today and was horrified to see the gap between my center section bars is almost 1/10" too big. Has anyone seen anything like this before? Should be 1.688, an it's actually about 1.750. It's a QB. Too big on the other side as well, but less so.
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 12-04-2010, 04:13 PM
TSwezey TSwezey is offline
It looks like they added one extra spacer when they were building it. Is like that one the bottom also?
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 12-04-2010, 09:07 PM
RV10Rob's Avatar
Yep, all too big--top and bottom, left and right, though this one is probably the worst. It also looks like the spacers that go on the AN3 bolts (page 29-21) are too long, which could be part of the problem. The space between the bars is correct in the center of the fuselage, but is too big at those spacers and where the wings go in. I don't understand how this thing could fit together with such a discrepancy. Will definitely call Van's on Monday, but was hoping someone out there had seen something like this before.
Thanks...
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 12-05-2010, 12:54 PM
Wayne Gillispie Wayne Gillispie is offline
Default Mine is 1.72" with all 13 shims installed
I have 4 large close tolerance bolts installed for alignment and 4 hardware bolts to pull it together on the shims. I did not deburr shims or check thickness of stack so I am sure ours is not the only ones off. Let us know what you find out.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 12-05-2010, 01:32 PM
aturner's Avatar
aturner aturner is offline
Rob, did you slip bolts in there and apply torque yet? I'm wondering, and I'm sure Van's will ask, how much the bolts will pull it together.
-Andy Turner
RV-10 N784JC
Old 12-06-2010, 12:35 PM
RV10Rob's Avatar
Called Van's, and they said the ~1/16" gap should be fine and that torquing down the bolts should pull it together. I will go ahead and try it.
It does seem counter-intuitive to me, though. I can see on the outboard side that the center section bars could bend that much, but on the inboard side, the wing bolts are just 1-2" from where the center section attaches to the rest of the fuselage. It doesn't seem like I should be able to bring in the center section bars as much as 1/16" without stressing something in the fuselage (like the AN3 bolts holding the center section to the rest of the fuselage).
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 12-12-2010, 10:47 PM
RV10Rob's Avatar
Update: the gap closed with minimal tension on the bolts, so I guess it wasn't a problem in the first place. One minor issue was that the gap made the bolt holes slightly misaligned, so I had to pull it together to get the first couple bolts installed. To do this, I took a couple of my 3/16" hardware store bolts, put them in the 9/16" holes (with a big washer) and tightened them down.
All done:
Thanks, all...
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
