Jack points
I bought carriage bolts from Lowes to screw into the wing. My jack is a tall bottle jack and the shaft terminates in a simple approximate 1 inch rod with a hole drilled through the end. I cut a piece of approximate 1.25 inch steel tube to slide over the rod and extend just above the rod to make the "receptacle". The tube bolted in place through the aforementioned hole in the jack shaft. Wish I had picture, it would be worth the proverbial 1000 words.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
