Old 12-04-2010, 09:08 AM
Len Len is offline
Default Wing Jacks
Does anyone know of where to buy a receptor cup that fits the black screw in wing jack points for the RV?
Len
Old 12-04-2010, 11:20 AM
dougmattson dougmattson is offline
You can make your own by drilling a 5/16 clearance hole in the end of a plumbing pipe cap. Or thread a 5/16 hole.
Then use a 5/16 x 18 bolt to screw into the wing tie downs. I used a 1in and 1/4 pipe cap to fit the jack stand I made.
Old 12-04-2010, 11:25 AM
N8RV's Avatar
N8RV N8RV is offline
Depending on your jack, you could also do the reverse -- use a stock bolt and round the bolt head. Then, make a deep dimple in your jack head that the now-rounded bolt head settles into.
The jacks I borrowed had the deep dimple, so it was an easy matter to just grind down a couple of bolt heads so that they mate nicely with the dimples, and swivel just enough as I jack the wing.
Just another option. Other side of the same coin, depending on your jacks.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 12-04-2010, 12:07 PM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
Default Another approach...
http://www.cherryfamily.net/gallery/....aspx?moid=744
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 12-04-2010, 12:32 PM
noelf noelf is offline
Default I bought mine from Aircraft Spruce...
...called Jack Extensions.
I used the 3" extensions, p/n 12-00157. In retrospect, I could have used the 1.5" extensions.
The extensions slide over the jack point on the 3-ton bottle jacks I have, and because the jack extensions are abt 3' deep, I need to unscrew the jacks' threaded jack point about three inches so that the lifting surface fits up inside and bottoms out inside the extension.
If you go this rout, also be sure to obtain a set of "collar clamps". They need to fit around the jack's hydraulic ram after you get the jack jacked up. You then fit the collar clamp around the exposed ram and clamp it down with the provided screws. This prevents the jack ram from retracting if it should loose pressure. Your jack ram diameter needs to be measured, and order the size that fits. I got mine from McMaster Carr
Last edited by noelf : 12-04-2010 at 12:44 PM. Reason: update with collar clamp info.
Old 12-04-2010, 12:42 PM
Master Designs's Avatar
Master Designs Master Designs is offline
Originally Posted by noelf View Post
...called Jack Extensions. I used the 3" extensions, p/n 12-00157. In retrospect, I could have used the 1.5" extensions..
Where do you get the black screw in wing jack points or what did you put/screw into the tie-down points to use with these jack extensions?
Robert Kramar
Gilbert, Arizona
  • Vans RV-6A
  • Bell 47 D-1 H-13 Sioux Army/Mash Helicopter - Fully Restored and Flying!
  • Vans RV-4 (being upgraded to new panel, firewall, weldments and long gear legs)
Yearly VAF dues paid to date.
Old 12-04-2010, 01:03 PM
Default The wing jack points...
...came from Van's Aircraft many years ago. The Jackpoint Kit contained two plastic/nylon screw-in points and a steel plate w/ U -bolt that attached to the gear leg. I do not know if they still carry this item.
If Van's no longer carries this item, you may want to ask them where they sourced the parts and let us all know.
Old 12-04-2010, 01:23 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Default Jack Pads
A 5/16" stainless carriage-head bolt works well. I screw mine in by hand until the bolt shoulder just touches the bottom skin. Matches the cup on the jack.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
