Old 03-23-2006, 08:22 PM
Walt's Avatar
Walt Walt is offline
Default Under Cowl Temps/SD8 Back up alternator
Getting ready to install SD-8 back up alternator and would like to mount the regulator/cap/relay on the firewall. Advantages are keeping the "noise" out of the cockpit, shorter wire runs, etc., disadvantage is higher temps which is not usually that good for electronic stuff. So if anybody happens to know what the under cowl temps run (I have a 7A 180hp) or has any experience with the setup I would appreciate the info!
Walt (TX)
7A 350hrs+ and luvin life!
Old 03-23-2006, 09:06 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Sample Size of One...
Walt,
I mounted my SD-8 accessories exactly as you described, on the firewall of my RV-8. I have no way to tell you what the temps are there, but I have had no problems with the system after four months and 120 hours. I personally think the temps are pretty reasonable on the firewall, since the really hot air should be captured by the baffles and directed down and out, but that is just a guess.
At any rate, one data point is...no problem!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
