Old 12-03-2010, 01:54 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Default Kuntzleman tail light mounting?
Hi, all... does anyone have a picture of their Kuntzleman position/strobe light mounted to the rudder fairing (standard location)? Looking at mine, the mounting holes seem to be too close to the edges of the tail fairing to work without modifying the fairing. Anyone else run across this issue?
Thanks..
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 12-03-2010, 02:07 PM
Brantel's Avatar
Brantel Brantel is offline
Mine fit my 7 but just barely...
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-03-2010, 02:13 PM
RV10Rob's Avatar
Thanks.... what are the screws going into?
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 12-03-2010, 02:20 PM
Brantel's Avatar
I filled the aft end of the fairing with flox and epoxy and drilled and tapped that. So far it is working great.
Old 12-03-2010, 02:55 PM
hydroguy2's Avatar
Me, too. the screws seem to get plenty tight just in the glass
Old 12-03-2010, 03:20 PM
cjensen's Avatar
cjensen cjensen is offline
I drilled two holes sideways in order to hold the nut in place, then I epoxied over the hole and nut to secure it...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 12-03-2010, 04:10 PM
RV10Rob's Avatar
Great... thanks much, guys. I thought about the epoxy/flox thing, but wasn't sure it'd hold. I may use a coarse thread, just to be sure.
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 12-03-2010, 05:44 PM
Captain Avgas Captain Avgas is offline
Default Best thread
You may go here to possibly the best thread on tail light attachment techniques (plenty of pix too).It's for an RV7 but the RV10 looks similar. Plenty of info in the archives on this topic.
http://www.vansairforce.com/communit...ad.php?t=20250
You’re only as good as your last landing
Bob Barrow
RV7A
