Old 12-03-2010, 01:22 PM
skyking902001's Avatar
skyking902001 skyking902001 is offline
Default Flap Brace Question
Question for those who have gone there before--Looks like when the flap brace is trimmed per the "notch to notch", it will leave less than minimum edge distance for at least the first rivet hole and very close to less on the second hole. I have sent an email to Van's, but have not yet had a reply. Did anyone else have a edge distance problem here?
Skyking902001
RV-8
Old 12-03-2010, 01:57 PM
bkthomps bkthomps is offline
cut on the right side of the blue line, then if it doesn't fit, use emery cloth to let it fit- don't literally cut the blue line
Old 12-03-2010, 02:28 PM
larrynew's Avatar
larrynew larrynew is offline
Yes, just did it. Cut fat, check fit, adjust as required. There's extra space on the spar to allow you to cut it without compromising edge distance on that one rivet hole.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 12-03-2010, 02:42 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Personally, my view is that although the e.d. is less than it should be, in this particular application is likely to be acceptable. Only a stress engineeer can know for sure. Still, for now you can always hedge your bets and do something like this:
If Van's tells you even that is not necessary, for consistency sake you can always trim away the "bump" later on.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 12-03-2010, 02:52 PM
WenEng WenEng is offline
Default Rick... you continue to offer insanely logical options....
In case someone hasn't thanked you recently. Thanks. That suggestion was not obvious to me but it should have been. Much more to learn and its not even my flap brace here....
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 12-03-2010, 03:12 PM
Default Many Thanks!
Thanks, guys! Sure makes more sense when viewed from a different persective!
Skyking902001
Old 12-03-2010, 07:23 PM
wildblue37 wildblue37 is offline
As long as you have 2*Diameter edge distance you'd be fine.
