Is it cured?
Kay,
You say "resin"...was it just resin or had you mixed it with hardener?
If it was mixed and has cured, MEK won't touch it.
If it is cured, the best bet is to flex the skin and it should pop right off. If flexing is impractical, carefully slide a single edge razor blade under the edge and pry up.
Build on,
Tim
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
