Old 11-29-2010, 05:56 PM
rph142's Avatar
rph142 rph142 is offline
Default Remote mounting the AFP Purge Valve
Hit another speed bump tonight. Just incase anyone is wondering, the RV-3 FWF is really tight...I mean REALLY tight. My purge valve control arm is hitting the top cowl at about half stroke. My two options are to remote mount the valve or to rotate the valve so the control arm is pointed down into the engine. I am wondering if it would be possible to mount the valve on the rear baffle or firewall, roughly 6" - 15" away from the flow divider (spider?). Has anyone had to remote mount the purge valve? Im guessing this is only an issue on RV-3's and 4's.
Rob
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 11-29-2010, 06:09 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Take a look at the thread in the 4 forum, by AXO----seems he had the same issue.
http://www.vansairforce.com/communit...ad.php?t=39772
Page 12
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-29-2010, 08:13 PM
DwightFrye DwightFrye is offline
If you currently have the "straight" arm on your purge valve, consider getting the "angled" arm from Don. It will give a little more clearance from the cowl, and might be enough to fix your issue. Regarding whether remote-mounting the purge valve is acceptable or not, ultimately the person who can best advise you is Don at Airflow. Give him a call.
Dwight Frye - Raleigh/Cary NC
http://www.openweave.org/rv7/
RV-7 N4932L/Tip-Up/Superior 180hp/API Fuel Injection/Boss Aircraft Paint
First Flight : September 2, 2013
Old 11-30-2010, 05:17 AM
pierre smith's Avatar
Default Here ya go..
Don, at AFP:
864 576 4512 EST,
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 11-30-2010, 05:25 AM
rph142's Avatar
Thanks guys, I'll be calling him today.
Rob Holmes
www.myrv3.com
N59LG
- Veluminati
Old 11-30-2010, 09:42 AM
Noah's Avatar
Noah Noah is offline
The purge valve is also available with left or right rotation to open, so that could potentially help this situation too.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 11-30-2010, 10:32 AM
rph142's Avatar
I just got off the phone with Kyle from AFP (Don was out). He said this is common on RV-3's and that they have a special bracket that remedies this problem. I am going to ship it back to them tomorrow. Ill post pics when I get it installed.
Rob Holmes
www.myrv3.com
N59LG
- Veluminati
