What was your sequence / procedure for aligning the gear leg fairings. Or are you relying on the geometry of upper intersections fairings to establish the alignment of the gear leg fairings?
The gear leg fairings must be aligned to the "displaced" aircraft centerline in a flight attitude with no weight on the gear. Once established, the intersection fairings (upper & lower) are positioned and attached to hold the gear leg fairings in that alignment position.
