11-26-2010, 03:25 AM
Protection for tow bar openings in fairing?
Any good ideas for protecting the nose wheel fairing so the tow bar does not take out chips or worse, due to misalignment when closing?
Something along the lines of a cap, but with a sleeve to provide some additional strength and protection? Might be a good place for stainless steel...
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
11-26-2010, 06:56 AM
I use 2" leading edge protection tape from 3M. It is lite, clear, and extremely tough.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
11-26-2010, 09:59 AM
That would work, wouldn't it?
Actual repeat offender.
11-26-2010, 11:28 AM
It doesn't take much skill to move the plane without a tow bar
It doesn't take much skill to move the plane without a tow bar and I have no tow bar holes in the nose wheel fairing. I did that for speed of course but it is an option.
Bob Axsom
11-26-2010, 01:13 PM
I've also seen heavier stainless steel tape used in the same location on Grummans. Cut with nice rounded corners.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
11-26-2010, 01:44 PM
Heat shrink
No, no, no..... just use some large diameter heat shrink on the tow bar. If you leave it just a little longer as the tubes of the tow bar, while shrinking it will "curl" around the edge of the tubes nicely. This will not only protect the inside of the hole in the fairing, but will also protect the sides of the fairing against hitting it with the end of the towbar tubes.
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
11-26-2010, 02:08 PM
I used thin SS and cut a circle the diameter I wanted. I cut a slightly smaller inside diameter than the finish size desired. I then used a round steel ball and centered the SS circle over a short pipe and tapped the ball , rolling the SS down into the pipe. This made a lip inside the wheel fairing. I then used a similar technique to contour the SS circle the shape of the fairing. Polish the circle and Pro-seal in place.
Both are still secure after 48 hrs flight time.
Ron
11-26-2010, 02:14 PM
Extending the bolts for the bar to go on cured all problems for me. They sit just slightly proud of the fairing now (about 1/8" over at the forward edge and recessed by about that much at the aft edge) which centers the bar nicely and prevents damage to the fairing (mine are not yet painted but I can see that the paint will not be in danger).
EAA Technical Counselor #5357
11-26-2010, 04:50 PM
Regards, Tonny.
Great idea Tonny! I am going to do that tomorrow! RonB has an elegant solution as well! I love this forum.
Bogert was going to send me an extended bolt solution a few months ago, but they never showed up and I forgot about it until now. I don't see anything on their web site about it, so maybe they dropped the idea.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
11-29-2010, 01:17 PM
Plastic Taped worked well
Thanks I just finished my 10 and have already scuffed the wheel pant paint. Maybe I should just over it. The virgin scuff is always the worst.
N595RV
Randy Means
Merritt Island Fl.
