Old 11-25-2010, 06:34 PM
flyboy1963's Avatar
Default winter ops - turning over the engine by hand?
Mostly for all you guys who store outside in below freezing climates; is it good, bad, or neither to go out and turn the prop by hand between flights?
The old standard is to pull it thru a dozen blades, which allegedly puts some oil on things inside, but I don't know the internal oiling system of a Lyc as well as a small-block chevy.
Does this really help?...or only as a pre-start ritual? I can't imagine it causes detrimental wear, as it would be the same as the first few seconds of operation anyway.
any engine gurus have an opinion?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 11-25-2010, 08:14 PM
Mel's Avatar
Mel Mel is offline
Default If you can't fly it, don't touch it!
Turning the engine only wipes oil off the cylinders and cam lobes.
The first few seconds of starting doesn't leave the bare cylinder walls exposed for weeks after wiping off the oil.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-25-2010, 08:18 PM
bfilarsky bfilarsky is offline
Ditto. I'm no expert, but everything I've heard is that its either detrimental or at best neutral. The practice of turning the prop through before starting comes from radials, where you're looking for a hydraulic lock.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW--What a Ride!" --Peter Sage
"Too many people are thinking of security instead of opportunity. They seem more afraid of life than death." --James F. Byrnes
RV-8 Empennage
Old 11-25-2010, 10:58 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Pulling prop through
Mel is right, all the old wisdom is leave it alone until it's time to run it.
Fuel Inj engines, when primed, dump fuel behind the intake valve so they are ready to immediately draw fuel into the cylinders.
Carbs with 4 cylinder hand primer should work the same as FI.
Carbs with an accelerator pump but no primer, pump the throttle a couple times then pull the prop through at least 4 blades. That precharges the cylinders with fuel so when you crank, you'll get all cylinders firing to get a good roll over and start. Worked like a champ on my Long-EZ.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 11-26-2010, 06:01 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Preheat Helps
Also in my opinion some kind of preheat before starting is needed in temperatures below freezing. I have a Reiff system with cylinder bands and a sump heater. It works great.
Jim Sharkey
RV-6
Old 11-26-2010, 07:31 AM
rv9av8tr's Avatar
Default Minimum temp for preheat
Actually, according to Lyc, preheating isn't required until 10 Deg F, except for the O-320 H series and O-360 E series, which is 20 Deg F.
Here is a good reference to cold weather engine operation:
http://www.lexingtonflyingclub.org/L...Operations.pdf
According to Premier Aircraft Engines, oil pan strip heaters should only be used 2 hrs prior to flight, otherwise the warm moist conditions created by the heater if left on all the time, will destroy the engine.
2017 Paid
Old 11-26-2010, 07:43 AM
zav6a zav6a is offline
Default Fogging oil
Anybody have opinion on using fogging oil like is used in marine applications for winterizing?
____________
Duane Zavadil
RV-6a, IO-320
Old 11-26-2010, 08:08 AM
Sam Buchanan's Avatar
been here awhile
I've been using a Reif sump heater for ten years. The heater runs 24/7 from November to April and no engine damage has occurred. Lots of info on this subject in the archives so I won't elaborate any further in this thread.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 11-26-2010, 08:40 AM
jsharkey's Avatar
Default Pre heat
All I was saying is that it sure starts easier, develops oil pressure and warms to operating temeprature sooner with preheat than without
Regular operation is probably a more significant factor in avoiding corrosion damage.
Jim Sharkey
Old 11-29-2010, 11:29 AM
flyboy1963's Avatar
Default don't touch it?
Okay, I can see some rationale for that.
Back to the oil pump thing, does anyone know if you are pumping oil to beneficial areas?...which would of course, inhibit corrosioin etc.
Or do need 10+ psi before it moves through the passages to the bearings etc.?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
