CDI signals - ok to run in multi-conductor shielded wire?
I'm working on the wiring for my nav indicator (KI209A) which will get wired to a KX155 and KLN89. For the four OBS signals (out/cos/sin/return), is it ok to run all inside a multi-conductor wire or do these signals need to go in separate single conductor wires? I can go either way, but it strikes me that it would neater if they were inside one multi-conductor wire.
Thanks!
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
