Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-23-2010, 05:29 PM
aeropark aeropark is offline
Default Garmin GTX330 to 496
Need info to display traffic from my GTX330 on my 496.
Old 11-23-2010, 06:13 PM
Brantel's Avatar
Brantel Brantel is offline
Connect the serial out line of the 330 to the serial in line of the 496. Configure the 496 to receive TIS data.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-23-2010, 08:04 PM
SteinAir SteinAir is offline
The appropriate data port, pinout and settings should be noted in both the GTX330 manual and also the 496 manual. Like Brian said, it's simply a single wire, it'll take more to setup the programming then it'll take to install the wire - easy peasy!
Stein
