  #21
Old 11-23-2010, 07:42 PM
If you are inclined to build, go with the 7.
If you are inclined to buy and fly, go with the 6.
Either way you can't go wrong. These machines are a delight to fly.
I take off for any reason - today it was to search for that deer I hit on Sunday. No sign of hide. hair or it. Maybe a hunter picked it up, the season was open that day and the deer may have been on the run because of it. I've ID'd the exact spot where it came on the road and it is all brush and tall grass on both sides. The front license plate was missing and that's where I found it, pure luck I'd say.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 11-23-2010, 08:18 PM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Better....,
My $ .02
The RV6 is a little shorter than a RV7. so....The RV7 has better pitch stability.
The RV7 has more fuel. More Better!
The RV7 has longer ailerons, 4". Better roll rate.
The RV 7 has more head room, More Better...........
I have flown, and built two RV6s, one had 500 hours, and the second one had 998 hours when I let it go. I have some 125+ hours in RV7s .
I did not think the RV7 would interest me untill I had a chance to fly several and use them as my own airplane.
The RV7 is a Better airplane, hands down.
I did not think I would like it when it first came the out. Or that I would need the 'improvements' that the 6 does not have. But the RV7 is a Better all round airplane than the 6. It is easer to build as well.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 11-23-2010, 08:29 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Good arguments Jay. But for someone buying a 6 or 7, would you say that the typical higher cost for a 7 is worth it?
If someone were to give me my choice of a 6 or 7 aircraft, I would probably take the 7(A). But I bought a 6A.
Old 11-23-2010, 08:37 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Too bad the larger counter balance tails of the 7's just look over sized & not dimensionally correct...........compared to the shorter, sportier, and eye pleasing "classic" tail of the original 6's.
L.Adamson --- RV6A (classic tail)
Old 11-23-2010, 08:44 PM
Jaypratt's Avatar
Default price
Buying or building?
Buying, a flying RV ? A RV6 is my choice. Since money is a limiting factor.
If money was no factor??? I would own 2 Grumand F8F Bearcats
one to fly when the other is down for mantience,,, No RVs for this hipothetical bizzilionair
Jay Pratt VAF #2
Old 11-24-2010, 09:15 AM
JonJay's Avatar
JonJay JonJay is offline
Default Are you sure Jay?
Originally Posted by Jaypratt View Post
My $ .02
I have not rolled a 7 but I have an 8 and my 6 rolls faster. I would assume a 7rolls just like an 8 or very similar. I searched the archives and this is a common opinion. Regardless, the difference is minimal and I would not make my choice on that alone.
I still prefer my 6, 'cause that's what I own!
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-24-2010, 09:23 AM
jjconstant's Avatar
jjconstant jjconstant is offline
Default landing gear
One other difference not mentioned...on the A models, the 6A sits a bit nose high on the ground and the 7A is almost level. Slight difference in taxi visibility, the 7 "looks" larger sitting on the ground and there may be some implications for rough surface operations but I don't want to cause thread creep!
Jeremy Constant
7A 90hrs, about to start my 1rst condition inspection!
Old 11-24-2010, 01:25 PM
Snowflake's Avatar
You'd think so, but it has longer wings, too, which results in an overall slower roll rate.
Having rolled both, I would say the -6 feels like it's rolling faster... But the difference isn't large enough to consider as a serious factor. They're effectively the same for the type of flying the RV was designed for... "gentlemanly aerobatics" I think Van calls it.
Rob Prior
Old 11-24-2010, 06:03 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Not too much larger span
Gents,
The RV-7's have a different wing tip design then the RV-6's. The new style angles out and adds about 6" per side. I doubt very seriously that this area adds any real performance improvements or degrades performance.
So the real effective span difference is about 1ft total.
I actually prefer the look of the old style tips over the batwings and the new style.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 11-24-2010, 06:33 PM
Martin Sutter Martin Sutter is offline
Super Moderator
It is not just the tip, the wings are longer too. Wing span for a 7 is 25' versus the RV6's 23'. There is also more leg and head room available. I have flown a 6 for 2500 hrs and a 7A for 600 hrs. and would agree with most of the previous comments. The most notable differences for me are the 7's greater load carrying capacity due to the larger wing area and more favorable CG envelope and the better directional stability due to the much larger tail. Both are great flying airplanes and I love them both.
Martin Sutter
building and flying RV's since 1988
EAA Technical Counselor
