Originally Posted by jclark
For normal formation, the plane does not need to be aerobatic.
The biggest "issue" I have found with flying the "9" in formation with the other 2-place RV's is the **WING**. The wing responds VERY differently in areas that matter a lot when you are close to another plane. And this is one of the things you get when trying to fly other "dissimilar" planes in formation.
I figured the "dissimilar" plane was the issue, thanks for clarifying for me.
So what you are saying is that a -3 would through you off as well because of its small size, it would also through off the "pace" of the formation?
Just busting on you James.
...Now for the Team RV airshow routine, we have addition "constraints" that we put on the planes to insure that we can do it safely and do it looking good...
For what you are doing with the airshow, I understand the requirement to have similarly equiped airplanes. When I watch the videos, I'm impressed at Kahuna's restraint at not out running the lesser powered RV's.
Originally Posted by ao.frog
Anyway; we're having alot of fun for now and that's what's it's all about, right?
Formation clinic in Norway? Great idea! And of course it'd be great to have US-visitors attending! I'll look into it and see if it'll be possible.
Maybe the formation wantabee's can fund a trip for some of the US instructors and lend them a plane or two. I'm sure you could drum up enough people and planes to make the trip worth it. Would your authorities recognize a US formation card?
Bill; THANKS alot for the nice offer to stay with you AND use your plane! That was REALLY nice of you! We'll see what the future holds...
No problem but you would have to put up with Torque the wonder dog.
Originally Posted by vlittle
...As for the comments about flying a -9 in formation with other RV's: It does seem like a lot more work because it's heavier in roll, but the biggest challenge is slowing down after the overhead break. Instead of slowing down to flap speed, I use a forward slip to bleed energy while keeping the airspeed up so that the following RV's (Swifts, Rockets) don't overrun me.
A constant speed prop would help here.
V
My problem with the -9, the few times I have flown with members of Team RV, is the landing. I have to slow down a lot more than the rest of the other RV's to get it on the ground and using partial flaps means I have to either slip it or come in shallower. A CS prop would help in this instance but that is not in the cards. (No need to comment on that statement LA!)
