Old 11-18-2010, 06:42 PM
szicree szicree is offline
Default A (dumb?) Question About Batteries
Is it possible for a battery to fail in such a way that it puts out only 7 volts, but still cranks the motor very well?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 11-18-2010, 08:27 PM
NDrv8r's Avatar
NDrv8r NDrv8r is offline
Default battery voltage
Is the 7 volts before or during cranking?
If it was before cranking, I would suspect a problem in the voltage measurement since 7volts would be quite dead.
If you are measuring 7 volts during cranking, I would not get overly concerned.
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
Old 11-18-2010, 09:00 PM
airguy's Avatar
airguy airguy is offline
If you're measuring 7 volts BEFORE cranking, and your engine still cranks normally, your voltage meter is shot and the battery is fine. 7 volts during cranking would not be too much out of normal.
Old 11-18-2010, 09:03 PM
It was before cranking. I think I've got a bad meter. Thanks.
Steve Zicree
Old 11-19-2010, 06:28 AM
vic syracuse vic syracuse is offline
Super Moderator
Yes, you probably have a bad meter, BUT 7 volts during cranking is not right either. A good battery should only drop to 9.3-9.6 volts during cranking.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
