11-18-2010, 03:18 PM
Wiring a 3 volt accessory
I have a GoPro camera mounted in my -4. The problem is having AAA Lithium batteries on hand (and installed) when I need them. I would like to install a circuit that comes from my aircraft's wiring system and runs into the camera that I could control from my switched panel. Has anyone got any ideas? This would have to drop the voltage from 12V down to 3V. If anyone knows of any "gotchas" I should look out for, I would appreciate hearing about those also.
11-18-2010, 03:22 PM
Check with Radio Shack or other electronics store for an adapter. They usually have several options for various voltage outputs.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
11-18-2010, 03:32 PM
LM317 adjustable voltage regulator, cheap & pretty simple to build one. Do a google search and you will find plenty of reference material on how to put one together. Total cost probably under $5
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
11-18-2010, 04:00 PM
12v to 3v
Try this:
http://www.powerstream.com/dc6.htm
M. Wyss
RV4 in the paint booth
and firewall forward
11-18-2010, 06:28 PM
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Twenty Six years after graduating college, LM317 immediately popped into my head too  Here's a very simple circuit that I found for you, Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
11-18-2010, 06:48 PM
Does the camera have a USB port? If it will record while powered over USB and no batteries, that might simplify things...
