anodised conductivity
Any anodised surface has poor conductivity, to gain a good electrical bond you need to remove the anodised finish in that area, at work I use what we call a bonding brush, you could probably find it at yard store, its basically a wire brush that grinds away the finish, before assembly treat the area with alodine 600 if available to maintain the corrosion protection whilst still allowing the bond
Hope that helps.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
