Dumb Air Oil Separator question
This is a little off-thread since it's not an RV problem per se. I do have an RV-4 and there seems to be a wealth of knowledge here, so I'll give it a try . . .
I have an Airwolf Air/Oil separator that routes into a Pesco Vacuum Pump. Does the breather tube that goes into the Vacuum pump go into the "IN" port or the "OUT" port (on the vacuum pump itself)? This is a Continental Engine, and the Airwolf directions just show the hose going generically into the vacuum pump, but doesn't specify which port to put it into.
Rick
