w/a Donation
VAF on Twitter:
@VansAirForceNet
  #221
Old 12-31-2017, 08:47 AM
Harvey rv12 Harvey rv12 is offline
JAE;
Did you post pics?.
Would like to see. Am thinking you are drilling through the engine mount tube?.
Tom O.
RV-12, bought flying
Hoskins Field, 44T
Olympia WA
the bitterness of poor quality
lingers long after the cheap
price is forgotten.
Old 12-31-2017, 12:30 PM
Originally Posted by John-G View Post
Jim-
Thinking about it Dale is probably right about 8mm being the size for the hex socket needed and it is in the HF hex set.
I am also remembering 8mm
What works really well is to purchase just an 8mm ball end allen wrench and cut of the short "L" leg and insert it into a socket.
That gives you an approx 4" long skinny extension beyond your socket.
BTW, only the very first cooling shrouds produced required modification to access the upper left bolt. Any produced in ~2009 and later will require no modification.
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips, ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR & Pre-purchase inspection Services
A&P, EAA Technical Councelor
