Old 03-21-2006, 07:40 AM
Bob Hoffman Bob Hoffman is offline
Default Retro fit crotch belt
I have a rv6a that I'm rebuilding .Interior and floor boards are out , so I thought now would be a good time to add a crotch strap.
Is it possible to retro fit and what parts do I need (can't find any mention in the plans) and proper placement and/or comments would help.
Bob
Old 03-21-2006, 08:07 AM
Vern's Avatar
Vern Vern is offline
Default Hooker Crotchstrap-RV-6A
I installed Hookers in my 6A. I bought the 7 crotchstrap kit but did not use it. I used 5/8 inch high strength bolts and two large steel washers per rib. I pre-drilled the washers (used as strengthening doublers) so I could pop rivet them on either side of the ribs similar to the fuel drain fittings on your wing tanks.
Remember,all this work is done via 90 degree drill and between some narrow rib spacing.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
