Old 11-16-2010, 06:05 PM
s24789 s24789 is offline
Question USB Hub for Garmin 496
I have a 496 mounted in an airgizmo panel dock. The single USB connector on the rear of the unit is to be used for XM Weather. My thought was to connect a hub to this port and run the XM Weather off one end and then plug in another USB cable when it was time for the monthly database updates to the unit. Has anyone done this or is there a reason this is a dumb idea. This would keep me from having to pop the 496 out of the mount to update the database.
Thanks in advance
phelps
Old 11-16-2010, 06:32 PM
RWoodard's Avatar
RWoodard RWoodard is offline
I'm interested in hearing the answer to this question, too. I'd like to do the same thing.
For now what I've done is installed an extension to the USB cable effectively moving the port to the lower edge of my instrument panel. When I want to do an update or download a track, I unplug the XM antenna and plug my USB cable in from my computer.
This method works, but it's not nearly as elegant as an installed solution would be. I'm hoping the collective wisdom of the VAF community will provide an answer.
BTW, I called Garmin and they couldn't/wouldn't answer the question.
Rod Woodard
Brighton, Colorado (CO12)
RV-3 N87CT (Thanks Chuck!)
Glasair 1RG N388DM
RV-3 N99RV sold 01/2000
F1 MkIII empennage?arrived 08/22/2018--collecting dust
Old 11-16-2010, 06:36 PM
mburch's Avatar
mburch mburch is offline
I kind of doubt a hub will work there...
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 11-17-2010, 10:29 AM
breister breister is offline
I may be out on a limb here, but I think that in order for a hub to work the 496 would have to be capable of "registering devices." With more than one item on the network, how would the 496 "know" when to go into software update mode and ignore the other attached devices?
My guess is that it MIGHT even work with only one device attached to the hub, but will "go stupid" when you add another or simply pick the first.
But, please try it and let us know if it works!
Old 11-18-2010, 03:44 AM
Smile
Rod spoke with Garmin today and the only way they know is the extension trick you have come up with. I asked if the connection was a proprietary format or configuration and they said no it was conventional. My extension cable is on order.
Phelps
Old 11-18-2010, 10:08 PM
RWoodard's Avatar
Cool.
My 496 actually came with an extension cable. It had a male mini-usb on one end and a right-angle female mini-usb on the other end.
It works, but it's still not as nifty as a permanent mount solution. Oh well.
Rod Woodard
Glasair 1RG N388DM
