Old 11-15-2010, 07:53 PM
DEWATSON DEWATSON is offline
Default oil cooler line hook up
Does it matter whether the pressure line from the engine is connected to the top or the bottom of the oil cooler when installed by the plans in a RV8? Mine is hooked to the top which forces the oil from the coolest part of the cooler to the hottest part and then back into the engine. I can't get this thing to cool properly and I have done everything in the book to seal it all up. There's no wasted cooling air. The only way out is through the oil cooler or down through the cylinder cooling fins. Does the direction of oil through the cooler matter?
David Watson
49FD
Old 11-15-2010, 09:42 PM
Walt's Avatar
Walt Walt is offline
I believe standard practice is to have the supply (pres) on the bottom in order for the cooler to naturally purge itself of air. Makes sense to me and seems to work
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-16-2010, 06:25 AM
It does make sense......I'll change mine and put the pressure line on the bottom. If I fly for 12 to 15 minutes now, the oil temperature will slowly creep toward 230 degrees. I've just started the phase one flying and this is the worst obstacle to overcome after 5 hours in the air 15 minutes at the time. Like I said, she is sealed up good enough to hold water and I've had no luck yet. I'd like to see the oil temperature no higher than 210 degrees. Thanks for your reply.
David Watson
49FD
Old 11-16-2010, 06:46 AM
AltonD's Avatar
AltonD AltonD is offline
Reverse the lines. It is rumored to be worth 25 degrees.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 11-16-2010, 08:55 AM
logansc's Avatar
logansc logansc is offline
I made about 20 changes under the hood on mine during the first 25 hours or so and nearly all of them helped a little. The one that didn't seem to do anything was swapping my oil input hose from top to bottom. I still feel it's worth doing just to guard against trapped air in your cooler, but when I did it, it didn't make any difference to my oil temperatures.
It's likely that you if you have a reasonably standard configuration, your baffles are well sealed, your wrap around cylinder baffles have the right size openings underneath and your oil cooler is a good one, then you are mostly just waiting on the engine oil rings to seat. When they do, you will see a dramatic drop in oil temps more or less immediately. I'd swap your oil lines as a precaution, but unless your engine "sets up" coincidental with your oil line swap, I'd be surprised if you see much of a difference. Just my experiences, others have seen it this way too, however...
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
Old 11-16-2010, 09:33 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
David,
The feed line must be at the bottom fitting of the cooler to get and keep any air bubbles purged out of the cooler core.
If you're using the Niagara (NDM) model number 20002A 7-row oil cooler as supplied in the Vans firewall forward kit, prepare to spend some more money upgrading to a bigger oil cooler. After looking thru your past posts (http://www.vansairforce.com/communit...67&postcount=1) it seems that you have the very exact same engine (America's Aircraft Engines-built ECI Titan IO-360) as we do on the RV-8 in my avatar. The little NDM oil cooler will *NEVER* be able to keep this engine cool unless you only fly in sub-50 degree Fahrenheit temperatures. It simply lacks the thermal dissipation capability.... period. It's really meant for no bigger engine than an O-320 or perhaps a low-performance carbureted O-360. We finally upgraded to an expensive $650plus SW 10599R cooler to get oil temps down to the 190-210 range in Texas summer heat and it's working extremely well. A cheaper alternative is the AeroClassic model #8000081 10-row cooler, which you can buy for around $260 from Aircraft Spruce. Another fellow here on VAF put that cooler on his similar-engined RV-7 in place of the NDM 7-row and achieved about the same results we did with the twice-as-expensive SW cooler. The 10-row will fit on the rear baffle of cylinder #4 on an RV-8, because I had a 13-row AeroClassic cooler mounted there for a short while, but the 13-row was just barely touching the inside of the cowl and almost wanting to rub the motor mount frame when the motor shakes during startup, so it had to go as well. 13-rows cooled too well --- 155-160 in Texas heat ;-) .
BTW, after reading your above-referenced post from July 2009 about your fuel injection issues, we had similar issues with the ECI fuel injection system after first startup, and found a mechanic who had a special set of fuel pressure gauges and hoses he had made for calibrating his Beech Debonair (very similar constant-bypass-flow Continental fuel injection system, from which the ECI design was derived) and he was able to calibrate the complicated ECI system for us according to the book, by using his gauges, and after that, the engine runs beautiful and hot starts are a complete non-issue with this fuel injection system. Getting the ECI system calibrated correctly for the particular engine it's installed upon, is absolutely crucial.
Neal Howard
Airplaneless once again...
Old 11-16-2010, 09:48 AM
trib trib is offline
I had a similar issue with my RV-6A which turned out to be that the oil cooler was not mounted high enough on the baffle. The plans called out for the cooler to be as high as possible, and I took this to be place the doubler (as provided) as high as possible on the baffle. I later found out that to locate it properly, you had to trim the upper left corner of the doubler off, raising the cooler about 1 1/2" from where I originally had it. This dropped my temperatures in the summer from 225F down to about 200F. On a trip to Charlotte 2 weeks ago, oil temp was only 165F in cruise. Now it looks like I need to cover a portion for the cooler months!
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 11-16-2010, 10:39 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Just another data point for you David - my RV-8/ O-360 combination has the standard Van's 7-Row cooler, with the inlet to the cooler on the bottom, and the only time I have oil cooling issues is climbing out of Phoenix in the summertime after a quick turn fuel stop. Cools just fine all the rest of the time (unless I have been doing excessive slow flight). Houston climatology.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-16-2010, 10:47 AM
Neal@F14's Avatar
Paul, does your IO-360 have the piston oil squirters in it?
On these ECI Titan IO-360's, they're averaging 15-20 degrees higher oil temps than the engines without the squirters, but they're also getting way lower cylinder head temps out of this deal too.
Neal Howard
Old 11-16-2010, 11:01 AM
Ironflight's Avatar
No, it doesn't Neal...but then I run CHT's in the lower 300's in cruise. Makes you wonder if the squirters are a good trade!
Different engine, different goals.
Paul F. Dye
