Old 11-14-2010, 06:38 AM
Bob_pipedream Bob_pipedream is offline
Default Marvel Jet size
Hi all,
Got my jet in front of me - it is a 47-773 from an MA-4SPA 10-3678-32 carb.
Everyone's drill the jet sites say that I should go (drill) from something like #40 hole to #39. I don't have a #39 drill at the moment, but a 2.5mm #40 drill feels very slack in the hole (i.e. so slack that it must already be a #39).
Now this is in a new engine and with a new carb - I doubt very much that any one has already drilled the jet.
Would anyone be able to tell me the diameter of the #47-773 jet when new?
Old 11-14-2010, 02:02 PM
Hi would anyone have a parts list for the 10-3678-32 or something that would tell me what the part number for the locking tab on the jet is?
Can not find it anywhere and the only numbers I can find are for the O-360's carb...
Old 11-14-2010, 02:11 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Here You go...
http://www.flycorona.com/manuals/mar...3678-32_pm.pdf
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-14-2010, 02:16 PM
Default BTW...
The 10-3678-32 is one of the richest running carbs for the O-320, you should not be having any issues as set-up factory. I'm thinking you have another issue as to the problem you have discribed.
Reiley
VAF# 671
Friend of the RV-1
Old 11-14-2010, 02:19 PM
Absolutely brilliant - thanks, now I can order the bits first thing in the morning,
Thanks again,
Bob
Old 11-29-2010, 04:15 AM
Default update
Hi All,
Just to say that I found my #47-773 jet to have a #38 hole already ? my carb was new and I do not think it had been touched by the engine builder. This some what confused me as it should be stock and I expected a #41 or 40.
I left the jet alone as I had already found an issue with the sump where Superior supplies one sump for either the O-320 or O-360. Problem is that the sump favours the wider diameter carb on the O-360 so on an O-320 there is a step that causes all kind of turbulence and mixture distribution problems ? see Lycoming SB258 and other thread.
I may still need to drill the jet, but it is now clear that the main issue was the sump as she is now very much smoother and faster?
