Old 11-13-2010, 03:28 PM
sonny junell's Avatar
sonny junell sonny junell is offline
Default D-Sub question
Why should i used the pin / socket insertion style d-sub's (solder "or crimp" then insert pin in to the sub frame) vs the solder pot style where my only step is solder and be done?
Thanks for any input.
Time, patience, and perseverance overcomes all obstacles.
Our Kit log
www.westernsheetmetal.com
Old 11-13-2010, 03:35 PM
Walt's Avatar
Walt Walt is offline
The machined stlye pins/sockets are the best, crimp and install, no solder required. They are more reliable, easier to work with and of course... a little more expensive
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-13-2010, 03:47 PM
flion's Avatar
flion flion is offline
Easy replacement if a pin fails or breaks, easy addition of new pins if you haven't filled them all, easier to attach wires and then insert into connector as opposed to trying to solder in close proximity to other pins. Those are my top 3.
EAA Technical Counselor #5357
Old 11-13-2010, 04:11 PM
pczar3's Avatar
pczar3 pczar3 is offline
Smile Keeps the wire flexible
We use the crimp style at work because the solder can wick up into the wire making it more brittle at the pin. This is not a problem if you have a good strain relief but if the strain relief is loose you can stress the wire to the breaking point. In the old days the Air Force did not allow soldered pins for this reason
Hope this helps,
Paul
YMMV
Paul
N694BP reserved
RV-6A Very Slow Build!
Old 11-13-2010, 04:31 PM
az_gila's Avatar
az_gila az_gila is offline
Smile But even NASA...
Hope this helps,
Paul
YMMV
...does allow soldered joints if done to specification.
Check 6.14 here - http://workmanship.nasa.gov/lib/insp.../frameset.html
Soldering is OK if the wires are supported correctly in the shell strain relief. However, the dimensions are small in the solder cups and you might actually find the crimping easier.
Lots of electronics has historically been soldered and has worked fine under all sorts of vibration and stress, including all of the early stuff on the moon and Mars - my first US job in the early 70's....
PS - the Air Force also used lots of Hughes Aircraft missiles, satellites and radars with lots of soldered joints in them...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-13-2010, 08:45 PM
vlittle's Avatar
vlittle vlittle is offline
... and when you are upside down underneath your panel, it's hard to hold a soldering iron in your teeth, solder in one hand and the wire in your second hand.
The solder splash burns take a while to heal.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 11-13-2010, 09:54 PM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Default Third hand...
Vern
LOL - Never tried holding the iron in my teeth! And of course holding the connector (or whatever it is you are soldering to), in your third hand.
/\/elson
RV-7A Tip-Up
NW Austin, TX
Old 11-13-2010, 11:08 PM
Vern
HAHAH Yeah , that would definitely happen to me,
OK I am sold on the crimp pin / socket style thanks for the feedback
Our Kit log
Old 11-13-2010, 11:27 PM
az_gila's Avatar
Thumbs up Sections 2.01 and 2.02
..of the NASA link will give some good pictorial references of what a good crimp should look like - practice on a few first.
Gil Alexander
Old 11-18-2010, 08:41 PM
That is a great site< THANKS
Our Kit log
