Old 11-09-2010, 09:09 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Flap switch conflicts
I have searched the board but can't find anything specific to my question. I want my back seat grip controls to mirror the front other than the start button. My concern is with the flaps, since the switches can be in the up position, off is momentary. I have the flap control relay broad from vans. If one flap switch us up and the other is actuated to down will this burn the relay board, I am thinking that it would? So how do you control the conflict between the two flap switches?
I know TCW sells a flap controller that solves this issue, I already have the Safety Trim and Smart Start, I just want to avoid spending another $225 if there is a simple solution. I already plan a rear trim and flap lockout switch for when I am flying inexperience folks. I want the full controls for when it is me and another pilot.
Thanks for any advice or help.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 11-09-2010, 10:58 PM
Daniel Hooper Daniel Hooper is offline
I can't find a schematic of the Van's relay board, but if it is like Rosie's drawing here:
http://vansairforce.com/community/sh...ad.php?t=18372
you should be able to put the switches in parallel.
If the pilot switched one way while the copilot switched the other, it should ground both sides of the motor, resulting in a stop, not a short circuit.
If you want to take a chance, you can try it out, but it is taking a chance without more information.
Old 11-10-2010, 08:17 AM
You could rig up a trial circuit with an LED that glows green or red depending on the current direction to check it out. No risk.
I'm not certain but I think their 276-012, for $1.69, would do the job.
Or just use two ordinary LEDs, in parallel, set to turn on opposite each other - they only turn on with the current in the right direction, and aren't hurt with small current in the other direction, if I remember correctly.
Old 11-10-2010, 09:02 AM
RVG8tor's Avatar
Default Disable switch
I saw Rosie's drawing doing my search but it appears to only have one stitch in the circuit. I want two operational flap switches but I don't know how to wire it so that they will not conflict with one another.
I think I am at the point where I will just have a disable switch for the rear stick. When I am flying with someone who knows what they are doing I will enable the controls. I will be in one of the seats so I will make sure my flap switch is off then let the other guy fly with his controls. Besides, only one person should have the controls at a time. I know this is not fail safe but it does what I want cheaply.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 11-10-2010, 09:08 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
If both switches were mom-off-mom it would work.
But, you would loose the ability to "hit and forget" the up function.
A standard switch on the front, and a mom-off-mom on the rear might do the trick, but then again, I do not know.
If you are using the Vans flap pre-positioner, you could check with Brian at ShowPlanes, or in someone else s unit, check with them.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-10-2010, 09:27 AM
RVG8tor's Avatar
Default on-off-(on)
Mike,
Unfortunately I already have my sticks, I did not think of this when I bought them.
I have this control board from Van's http://www.vansaircraft.com/cgi-bin/...uct=flap-board I don't' think it is designed for more than one switch. I think I will use the suggestion above and run things to a light to see what happens when one switch is up and the other is actuated to down.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 11-10-2010, 10:46 AM
Mike S's Avatar
Senior Curmudgeon
If I am reading this correctly, and also reading the details of the Vans control board correctly, you may be in for a problem.
The Vans board looks to be only a way to handle higher current than the switch itself is rated at, it does not appear to have safety cutoff, or travel limit switches, and if your flap switch will stay in the up position, what is to keep the flap motor from running after it reaches full up travel??
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-10-2010, 11:11 AM
RV8R999 RV8R999 is offline
I have the vans relay board with two flaps switches in parallel (infinity sticks ) Theses switches are on - up, off-centered and mom-on when down. I wired up two micro switches (parallel with each other for redundancy) in series with the up ckt to shut motor down at the up stops. If the rear switch is left in the up position the front switch will bring the flaps down until the micro switches are no longer in contact at which point nothing happens. I cn reach behind me to disengage the rear flap switch if I fail to check on preflight. You won't burn up the motor as no current will flow with power connected to both sides which is the case with one switch up and the other down and didn't see any change in current indicating a short through the relays.
Old 11-10-2010, 11:23 AM
RVG8tor's Avatar
Default Good News
I did plan one micro switch to cut off the motor for the up position. I chose the up as a non momentary position so that on a go around I could just put the switch to up and forget it, the micro switch would prevent the motor run on.
So you set up is what I am look for, just to make sure you have two up micro switches? What is the abnormal that made you want an additional back up.
Also do you have a rear stick disable switch? I have read that you can combine the grounds from the trim and flaps to one side of a switch, by cutting out the ground to the rear stick you effectively make the rear stick inoperable for these switches. At least that is what I think will work. I am going to hook up the stick on the table and try my theory out before I intall them that way in the plane.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 11-10-2010, 01:00 PM
RVG8tor's Avatar
Default What Ken said
I hooked up both stick on the table and they work as Ken said. If the flap switches are opposite then the motor just stops. The switch on the ground wires to the rear switch does disable the flap and hat switch.
The only procedural gotcha that I have found is:
Flaps down any amount
Rear flap switch in the up position
If the rear stick is enabled with this configuration then the flaps will immediately move up.
Most likely if the person in back is flying the pattern the switch would have been enabled prior to flap deployment, there is no problem with the up position and enabling the rear stick as the micro up switch would not power the motor.
So procedurally there will be a step to ensure rear flap switch is off prior to enabling rear stick controls.
Thanks for the help. It seems with me and electrical stuff, I have to hook it up to see it work.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
