Old 11-06-2010, 01:01 PM
floridawing floridawing is offline
Default RV-6 vibration and smoking rivets!
Hello, I have a RV6 with a o-320. I do not have any carpet on the floor or sidewalls. It has about 200 hours total. The floor vibrates really bad in flight and I am starting to see some of the rivets attaching the floor starting to smoke! Most of the RV6 I see have carpet and side panels. Will adding carpet help stop the vibration and stop the smoking rivets.If carpet will not help I would like to keep the basic look. I do not want to replace these rivets. I have read some post on checking the exhaust which I will do. Thanks for your help.r help.
Old 11-06-2010, 01:33 PM
Aren't those the rivets along the main spar carrythrough bulkhead?
Can you confirm that the braces that tie the center section to the floor pan are installed? On one end, they attach to the fore/aft stringers on the cockpit floor and on the other end, they are bolted to the spar.
I always thought the drawings representing those braces would be easy to miss or mis-interpret.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-06-2010, 01:36 PM
dav1111 dav1111 is offline
Super Moderator
Default Vibration
You should probably have your prop balanced and see what that does for the vibration.
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Sold
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
Old 11-06-2010, 07:15 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I've seen those left out, and it certainly vibrates. I have carpet in my 6A now, but it wasn't bad vibration wise, before the carpet was installed.
L.Adamson --- RV6A
Old 11-06-2010, 09:16 PM
Thanks everyone for your help.I will look for the braces. I bought this already built.
Old 11-06-2010, 09:37 PM
az_gila's Avatar
az_gila az_gila is offline
Smile However...
...the braces are inboard on the fore-aft angles on the floor boards.
I would think no braces would smoke inboard rivets, not the outboard ones you picture.
Does it look like the rivets may have been initially under-driven?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-06-2010, 09:46 PM
Dmadd Dmadd is offline
what kind of prop do you have? Metal or wood? How many blades? Constant speed or fixed? Are you using auto gas? The back side of the wing drain looks like auto gas stains... More info.
Old 11-06-2010, 10:02 PM
koda2 koda2 is offline
Default Four attachments
Gil didn't mention this but, in addition to the two small F-699 brackets, the floor also attaches to the spar via the fuel selector assembly legs. The legs are bolted to the spar and riveted(or bolted) to the inner floor ribs. The 699s attach the outer rib on each side.
That way each of the 4 floor ribs is attached to the spar. It would be easy to forget the inner rib attachments as well.
I looked long and hard for the description of the 699s; it is in a small corner on DWG 46.
Dave A.
6A build
Old 11-06-2010, 11:47 PM
Thanks again for all the help.
Old 11-07-2010, 05:25 AM
apkp777's Avatar
apkp777 apkp777 is offline
No matter what might be missing, you will have to remove and replace those rivets. You might even have to go to a 1/8 rivet. Find a local builder, he (or she) will have everything you'll need to get it done right.
Tony Phillips
N524AP, RV 9 (tail wheel)
