Old 11-05-2010, 06:31 PM
dustman dustman is offline
Default drilling center section
For the experts what?s the best technique for drilling holes in alum that doesn?t destroy the material? Specifically I need to drill the boltholes for the center section bulkhead. I know a couple of wrong ways now. Is there a particular type of drill bit that works best or is a punch a better approach? Type aircraft RV3 Thanks for any help
Dustman
RV3B
St Marys Georgia
Dues paid 11-11-2011
Old 11-05-2010, 06:51 PM
Mel's Avatar
Mel Mel is offline
Not quite sure what you're asking here. If you are asking for normal drilling techniques;
For soft materials like aluminum, use high speed (air drill), low pressure.
For harder materials like steel, use low speed (electric drill), and high pressure with plenty of lubrication.
And it goes without saying, always use sharp drills.
A punch is fine if you have the correct size.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
