Old 11-05-2010, 03:41 PM
tdhanson tdhanson is offline
Default Buying kit from 2nd party but still get Vans Engine/Prop Discount?
I see you can buy the whole Vans Kit and then buy the engine/prop and get a pretty good discount. This is one per Vans customer number.
I called Vans and asked about buying a kit from someone (in new or partially assembled condition) and they said there is no charge to transfer the kit serial number to me.
Does transferring the kit serial no. to me also assign me a Vans customer number and then allow me to purchase the engine/prop at discount if it hadn't already been 'used' by prior kit owner(s)?
A second question would be what criteria and price would you put on a kit when buying 2nd hand. I don't usually see much markup for a persons time for partially completed tail/wings/fuse. In fact it seems the prices are less than a new kit.
A third question might be how much build would a person need to do to then become repairman eligible? Say if the wings and tail were already built but I then build the fuse and assemble all components, fwf, and avionics, is this sufficient?
Tracy
(looking to buy/build an RV4, RV7, or RV8 in order of preference and budget).
Old 11-05-2010, 03:52 PM
FresnoR's Avatar
FresnoR FresnoR is offline
In terms of valuation of a kit that people have worked on. Almost like a new car, the value typically goes down the second you unpack your kit. The new buyer is no longer guaranteed to have every piece, there may be damage or corrosion from pieces sitting too long, or if any workmanship is done, it may be shoddy. You will definitely find this true on the empennage kits. Buyers want a kit that is not touched, because they know it is a good kit to learn with. It is also a bad sign if someone is selling a halfway built tail, it means they probably got in over their heads with the build, which means they do not have much experiance with building, which can question worksmanship.
Sometimes you will find a builder selling his half built kit and try to get more money out of it than was put in, but that is an asking price and this rarely happens unless it has received its airworthiness certificate.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 11-05-2010, 04:01 PM
rleffler's Avatar
rleffler rleffler is offline
Originally Posted by tdhanson View Post
Does transferring the kit serial no. to me also assign me a Vans customer number and then allow me to purchase the engine/prop at discount if it hadn't already been 'used' by prior kit owner(s)?)
You inherit the kit number that was assigned to the original owner, so you are correct, as long as the original owner did make the purchase, you can.
Just like buying a used car. The best deal each party can negotiate.
First you have to be able to prove that 51% was built by non-hired help. This is probably not a problem if you have the build logs from the original owner. Many FSDOs will give you the Repairman's Cert if you are familiar with the build.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-05-2010, 04:08 PM
Mel's Avatar
Mel Mel is offline
Bob is correct. The "51%" concerns whether or not the aircraft is "amateur-built". It does not necessarily have a large bearing on the repairman certificate. To be eligible for the repairman certificate, you must convince the FAA that you built a sufficient amount of the aircraft to competently conduct the condition inspection. Typically, most FSDOs are lenient on this matter.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-05-2010, 05:48 PM
Vern's Avatar
Vern Vern is offline
Default Tax benefit
Depending on your state, you may have a tax savings if you purchase a 'used kit' vs a new kit. Similar to the tax on a new car vs a used car.
For this reason, a very slightly 'used' kit might actually be a better deal.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
