Old 11-05-2010, 02:20 PM
jackhammer jackhammer is offline
Default fitting flop tube to qb tanks with float senders
I have just started on my quick build wings and tanks and wanted to fit a flop tube to one of the tanks. The only problem I can see is getting in to the tank to rivet a small stiffener ring to the back of the tank for where the float sender is moved to in the second bay. Has anybody had this problem ? The only thing I can think of is to get another stiffener and use the supplied cover plate and cut a hole the size of the inside of this. This would then give me access to be able to rivet the ring on. any help would be great ta
Old 11-05-2010, 03:12 PM
jdeas's Avatar
jdeas jdeas is offline
Default Same issue, made a donut shaped douber then slotted
I built a doubler ring on the outside of the tank matching the float hole on the inside and extending out far enough to properly mount the nut plates. Predrilled all rivet and bolt holes by match drilling to the outside of the tank.
Then I slotted the doubler ring and bent to a slight corkscrew to insert into the tank via float opening. A little Proseal and a few rivets later I had my internal doubler/nut plates.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 11-05-2010, 05:16 PM
Default still confused
thanks JD but Im still a little confused
how did you go about riveting the stiffener on to the inside of the tank , I cant get my squezzer through the float hole or did you make a bigger access plate or use pop rivets to secure the stiffener on
Old 11-05-2010, 05:35 PM
jdeas's Avatar
Default Bucking Bar
I don't clearly remember. I think my squeezer fit the hole. It was that or I used a bar via the internal fuel vent.
At ant rate I did remove the outside rib but nothing else to accomplish this.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
Old 11-06-2010, 04:27 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default float attach
Here is how I did it.
http://www.rv8.ch/article.php?story=2004070219310174
I later undid this, since I removed the flop tubes after I determined that I didn't plan to fly inverted for long enough to cause a problem.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-06-2010, 12:34 PM
Thanks for all the info guys
Old 11-06-2010, 10:02 PM
DENMACRES DENMACRES is offline
Smile flop tube
I have a 6, when installing the flop tube I shortened the tube so as to miss the float type sender. This way it is not necessary to move the sender. Unusable fuel is only 1qt. It has worked well for 830hrs. thx Dennis
