Old 11-03-2010, 10:43 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default How did you hold this nut?
Gents,
I am finally assembling my RV-7A and I am in the process of installing the ailerons.
How did you hold the nut while torquing the upper bolt (on the aileron). This bolt secures the pushrod and access to the nut blocked by the nose rib of the aileron.
What tricks did you use?
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 11-04-2010, 06:36 AM
AlexPeterson's Avatar
Without a picture, it's hard to tell exactly what your situation is (they all differ slightly). Would it help to use one of those smaller all metal lock nuts? It allows using a much smaller wrench, and might help. I believe the hex is 1/4" on the -10 size.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 11-04-2010, 07:41 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Push rod bolt?
If it is the pushrod bolt, install the pushrod before you put the aileron on.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
