Old 11-03-2010, 12:01 PM
RKellogg RKellogg is offline
Default Eliminate Master Contactor ??
I am considering elimination of the master contactor to save weight and electrical load. Could use three 20A toggle breakers as "masters" to control the electrical systems. Any comments? Any experience?
- Roger
Old 11-03-2010, 12:11 PM
skybolt31 skybolt31 is offline
The Christen Eagle is setup without a master contactor, everything goes through a 20amp switch/breaker. It saves weight perhaps cuts down on electrical load and makes things a little simpler. The two drawbacks that I have identified (so far) is that if your starter contactor sticks, the starter will crank until the battery dies and if you do have a dead battery and jump the plane to start it, the charging current to the battery will exceed the 20amp breaker's capacity and it will trip when the rpm's are increased. Sounds like if you use several of them, this will not be a problem.
Bruce Green
Old 11-03-2010, 01:02 PM
MCA's Avatar
MCA MCA is offline
You can't run the starter load through those switches so you'll have the issue described above. Further, you won't be able to isolate power form coming into the cabin area.
The contactor draws about 0.7 amps at 14v. What is the weight delta between three beefy swithces and the contactor?
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 11-03-2010, 04:15 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
If you ever have an electrical fire start up during a flight. The ability to kill all your electrical power via shutting off a "master relay" is the next best thing to having a parachute (and enough altitude for it to work) onboard.
Neal Howard
Airplaneless once again...
Old 11-03-2010, 09:30 PM
gasman gasman is offline
How about a manual master switch? Harbor Freight has this........
http://www.harborfreight.com/catalog...battery+switch
Heavy Duty Battery Cutoff Switch
Item #66789
Only:$9.99
U.S. General #66789
This will carry starting load and also be able to switch it off manually if you need to isolate the battery load just like the master relay except it is a manual switch that does not use any power.
Old 11-04-2010, 09:01 AM
Crossbow Crossbow is offline
- Roger
I am still a good ways from this point, however the same thought has crossed my mind, therefore I am interested in the replies.
After all, Aircraft Spruce sells a little item that is called a "PULL SWITCH" (part number: 16-140) for $ 9.50 that can pull 75 Amps. Anyway, I should think that one can use a device like this as opposed to the Master Contactor unit.
Old 11-04-2010, 09:31 AM
rocketbob's Avatar
Your starter will draw 300-350A initially.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 11-04-2010, 09:57 AM
szicree szicree is offline
Item #66789
Only:$9.99
U.S. General #66789
No offense, but the idea of a Harbor Freight item keeping my plane in the air makes me very uncomfortable.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 11-04-2010, 01:23 PM
Wow! That sure is a lot of current all right.
However, if one kept the wiring for the Starter Contactor seperated from the other wiring, then that 300A to 350A should not be a factor.
So am I thinking about that correctly?
Old 11-04-2010, 08:47 PM
Neal@F14's Avatar
Using a master relay solenoid (contactor) is a tried and proven recipe. They don't weight or cost all that much, and there's very good reasons why virtually every production and homebuilt piston engine aircraft on the planet has one.
Neal Howard
