Old 11-02-2010, 10:07 AM
MCA's Avatar
MCA MCA is offline
Default Save $300: Vertical Power VP-X & MGL Xtreme Bundle Special!
Save $300 on Vertical Power VP-X and MGL Xtreme EFIS Package
Special good through Dec 31, 2010
Vertical Power and MGL Avionics announce the integration of the MGL Xtreme 4.3" EFIS with the Vertical Power VP-X Electronic Circuit Breaker System. The MGL Xtreme size is perfect for use as a primary EFIS in panels with tight space or as a backup EFIS. If your primary EFIS does not support the VP-X, the Xtreme provides an interface for the VP-X, allowing pilots to view electrical system status and reset faults. Additional modules can be purchased that provide attitude display and engine monitoring capabilities on the Xtreme.
Save $300 when purchasing the Xtreme & VP-X Pro and save $150 when purchasing the Xtreme & VP-X Sport package. A software upgrade from MGL will be available in Q1 2011 to support the integration. Act now, offer is valid for systems ordered Nov 1 2010 to Dec 31 2010. Systems in bundle are expected to ship no later than December.
MGL Extreme and Vertical Power VP-X Pro:
Normally $2900, bundle price $2600
MGL Extreme and Vertical Power VP-X Sport:
Normally $2300, bundle price $2150
Systems must be ordered together as a bundle.
Don't forget:
- Wiring harness for VP-X
- Optional AHRS and engine data module for Xtreme.
The VP-X/Xtreme bundle is available from Aircraft Spruce, SteinAir, Aerotronics or directly from Vertical Power and MGL Avionics US.
For more information:
VP: http://www.verticalpower.com/VPX.html
MGL: http://www.mglavionics.com/html/xtreme.html
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 11-05-2010, 08:08 PM
turneraero turneraero is offline
Thumbs up
Marc,
Any chance there will be a bundle special with an Oddessy or Voyager?
Jerry Turner
RV9A Finishing
Old 11-08-2010, 10:56 AM
MCA's Avatar
MCA MCA is offline
Jerry, We are not currently planning on that.
Marc Ausman
