Old 11-01-2010, 12:57 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Talking Good news for NorCal Experimental Aircraft
The local FSDO has loosened the test flight restrictions for some local northern Calif airports.
For the last couple years, the local FSDO has prohibited any test flying out of Cameron Park, Placerville, Nevada City, Sacramento Exec, Alta Sierra, and possibly a few others.
Experimental aircraft builders will now have the ability to deal with flying out of their home airports as outlined in a memo dated 10-27-10.
Details can be gotten from the Sacramento FSDO,
I will try to post or link to the actual memo, (which I can not do at this time) shortly.
I can email the memo to folks, if needed, just cant figure out how to put it online. If one of you can put a PDF file up on the forum, I will send it to you.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-01-2010, 02:13 PM
N427EF N427EF is offline
Good news indeed!
Eagerly anticipating news of your first flight too.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 11-01-2010, 04:56 PM
Lars Lars is offline
Good news, Mike, though I'm fortunate enough to not have been affected either way. Does that mean you can move back to Cameron Park?
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 11-01-2010, 05:05 PM
hydroguy2's Avatar
very cool Mike.
one question though....How did common sense prevail in California?
Old 11-01-2010, 09:25 PM
Mike S's Avatar
Senior Curmudgeon
Originally Posted by hydroguy2 View Post
very cool Mike.
Common sense ?? Well, a couple years ago our EAA chapter pres got involved, had a meet and confer with the FSDO folks, and then at Oshkosh, took it to the powers that be there also.
I am absolutely sure that if EAA was not in the picture, this would never have happened.
We do win one once in a while
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-01-2010, 09:28 PM
RV6_flyer's Avatar
Default Link to Sacramento FSDO Letter / Memo dated 10-27-2010
A scanned copy of the letter or memo can be found here:
http://www.rvdar.com/files/Sacrament...-2010_Memo.pdf
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-01-2010, 11:37 PM
Mike S's Avatar
Senior Curmudgeon
Default Thanks!!
Thanks Gary, I had no idea how to do that.
YOU da man
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-02-2010, 03:40 AM
rleffler's Avatar
rleffler rleffler is offline
U.S. Department of Transportation
Federal Aviation Administration
Sacramento Flight Standards District Office
1102 Corporate Way, Bldg B
Sacramento, California 95831
Phone (916) 422-0272
October 27, 2010
Dear Experimental Aircraft Enthusiast:
The Sacramento FSDO applauds you for your efforts in producing your own aircraft in an effort to keep general aviation alive while allowing you to do what you love, that is to fly. In an effort to try to better serve you and to promote aviation safety in the experimental aircraft community the Sacramento FSDO is introducing a new procedure for conducting your initial flights in your aircraft. In the past we have been required by authorities at a higher level to restrict some or all of your initial flights out of some airports. This restriction made it necessary in some cases to remove portions of your completed aircraft in order to trailer your aircraft to a more suitable airport for the test flights. This restriction was mandated to provide an extra level of safety for persons and property on the surface. The analysis of potential airports that would be restricted was based upon aerial over flights of the area surrounding or near the airport as well as the evaluation of the departure and arrival corridors. The primary objective was to ensure the safety of the congested areas of housing and businesses on the surface in the event of some type of malfunction requiring an emergency landing or other catastrophic event.
After a thorough review and an evaluation of your comments it has been determined that other methods could be utilized to provide that same level of safety for persons and property on the surface while also reducing the potential for re-assembly errors when aircraft are moved to another airport. Based upon your recommendations we are now removing the restrictions previously put in place at certain airports. However, we will require that you submit your plan for departure and arrival at your home airport to the Sacramento FSDO for evaluation. The plan must be designed to mitigate any undue hazard to persons or property on the surface in the event of an unforeseen malfunction.
The Sacramento FSDO hopes that this change will better meets the needs of the experimental aircraft community while at the same time increases the level of safety for all involved.
Sincerely,
Gregory L. Michael
Manager, Sacramento Flight Standards District Office
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-02-2010, 07:19 AM
Greg Arehart's Avatar
Also its worth asking for a larger test area. The local FSDO in Reno has been giving RVs a 100-mile radius test flight area because a number of us have argued that it is 1) important to be able to go over the hill to Sacramento valley to break in the engine at near sea level; and 2) RVs go fast enough that 50 mile radius is insufficient to really test the airplane properly.
cheers,
greg
Greg Arehart
N 7965A
Old 11-02-2010, 10:34 AM
jsherblon's Avatar
jsherblon jsherblon is offline
Good news - Thanks, Mike (even though I'm in the Oakland FSDO region)
Jim Sherblon
-7 Slider Finishing Kit
Stuck in Lodi CA
