Old 10-31-2010, 07:08 PM
odlee odlee is offline
Default New engine mount install question
For those of you who have replaced the motor mounts, do you have any suggestions as to sequence, top or bottom first. I am going to replace the mounts on my currently flying -7 and would appreciate any "helpful hints". Is it a one man job or should I provide adult beverages to volunteers?
David
Old 10-31-2010, 08:21 PM
Walt's Avatar
Walt Walt is offline
I did this a few years ago when I replaced the stock Van's mounts with new Lord mounts. Just me and an engine hoist. If I recall correctly I loosened them all up did both bottoms followed by the tops. Kinda like installing the motor, the last one can be a bit of a pain to get lined up after you tighten the other 3 down.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-01-2010, 08:16 AM
Default Thanks Walt
That is exactly what is going to happen to the -7. I just need to plan what is going to be disconnected, etc. to allow enough engine movement to r&r the mounts. I am positive there will be no muttering and other slang terms in the air while the work is taking place!
David
