10-31-2010, 06:56 PM
Back-rivet set roll pin...
ARGH!
My back-rivet set broke the roll pin that hold the nylon collar on. This is a 1/8" roll-pin and both ears broke. So, I went to McMaster-Carr to get them and guess what? you have to order 100 pins! *sigh*
So, if anyone out there has a broken pin on their back-rivet set, send me your address and I'll send a couple.
*sigh*
Dkb
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
10-31-2010, 07:08 PM
Senior Curmudgeon
NAPA auto parts sells roll pins, and you can buy only one
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
10-31-2010, 07:22 PM
This has been a common failure for many years.
20 years ago I repaired mine by cutting a short piece off of an appropriate diam. (dull) drill bit (the un-fluted shank portion) with a cutting disk and tapped it into the hole. It has been that way ever since.
Scott McDaniels
Hubbard, Oregon
10-31-2010, 09:01 PM
Try ACE hardware
Ace Hardware carries these pins.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero- HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
10-31-2010, 11:38 PM
OSH has them, too...I have a handful in my tool box, because they seem to fail at the worst possible time.
I had an offset backrivet set that had a roll pin fail within a week of getting it... grrrrr....
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
11-01-2010, 08:17 AM
When the one I bought from Avery did that, I contacted them and received a few.
EAA Technical Counselor #5357
11-01-2010, 09:47 AM
Same thing happened to mine. I just cut a finish nail to length and bent the ends so it would fall out. This has worked fine for many years
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build  )
N621TR In unrestricted operation
