Old 10-27-2010, 06:48 PM
Kevin Horton's Avatar
Default O-320-D Power Spreadsheet Available
I created an O-320-D power spreadsheet, just in case anyone is interested. It replicates the Lycoming power charts for the O-320-B and -D engines, except for the O-320-B2D, -B2E and -D2J. It is only valid if the mixture is set for best power.
I ran a few test cases against the paper power chart, and it seems to match OK. I'd like to find a power table from the POH of some type-certificated aircraft to check it against, but I haven't found one yet. Can anyone point me to any type certificated aircraft with constant speed props that used one of these engines? Fixed pitch power charts are useless for this purpose, as they don't provide the MP.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 10-27-2010, 07:19 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Kevin,
At least on my copy, lines 11 -12 and 21-120 don't show up in the spreadsheet that I can see. These contain the equations that you used to generate the hp numbers.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 10-27-2010, 07:21 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
All Zipped up...?
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 10-27-2010, 07:59 PM
cguarino cguarino is offline
Default Excel tutorial
Unprotect the sheet and then unhide the rows. Lots of info there.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
