Have you ever looked at a picture included in someone's post, and put on your Sherlock hat? I find myself doing that - someone posts a picture and then includes a little background about the picture - and then I look for the clues to back up "The Story".
For example...
I included this picture of my panel in another thread, and mentioned that I was descending into Provo airport KPVU. Now, descending into an airport is a pretty boring subject. There's no
pizazz!! to such a simple sentence. But after looking at the picture, there's a lot of information that adds to the story.
For example, the radio frequencies are the correct CTAF and ATIS freqs for KPVU after the tower closes at 2100. But the clock on the Dynon says that the time is 2017. Am I on the wrong freq? (No, the clock is showing Pacific Time, but Provo is on Mountain Time).
The transponder shows a pressure alt of 7590ft descending, and the EFIS is showing a descent of about 1000fpm. This backs up the discrepancy between the manifold pressure/prop (12.6"/2400rpm) and the fuel flow of 4.3gph and the speed of 152 IAS/178 mph TAS.
The indicated alt is 7580, and the density alt is showing 10680'. This makes sense based on the temp of 79F. If you look real close, you may be able to see the Kohlsman window is showing almost standard pressure at 29.90.
So Watson... did I miss any clues?
